Hello
I found the center joypad button seems to be not much precise and it's easily to press it and do another move (up-down-left or right)
Could it be my device or all the joypads comes some easily to make a mistake?
cya
Hello
cya
Mine works quiet good .. the odd one out is the 6600's joypad ... if u changed ur cover or you use a transparent cover on top .. then i guess u have a lil problem using the keys ..
perhaps needs more using it, because I just have it for 1 week so far 😉
cya
CasperVD wrote:perhaps needs more using it, because I just have it for 1 week so far 😉cya
if u changin teh cover try using the original keypad ... always better
