Operator Software Removal
2 replies · 2,257 views · Started 11 September 2004
I just got a new 7610 cause' my old one had major software problems and I returned it. It's working fine, but now whenever the screen goes into standby, I keep getting this kiddie screensaver from my servce provider and it flashes for a minute or so before the usual clock/date appears.
Also, instead of saying i.e "ABC-900" in normal font at the top of the screen, now theres this colour operator logo that appears over my phone's theme. (Like a pic of the company logo) It's not causing any problems but it looks quite ugly.
Any way I can remove this stuff? Thanks.
binnyrox wrote:Hi,
you should be able to get ridd of them in the settings menu and sub menu's!!
Ok thanks a million, I found the screensaver options under "Themes" . Can't get rid of the operator logo though, nevermind.
