do you think it's possibleto make a radio application for the 7650 ????
radio
I could see an application that can stream stuff of the net but as far as normal type radio receiver for free to air stuff then I would think no. You firstly would need to get the nokia to pick up radio signal, decode them then output them. Then you would need to run headphones from the phone so you could actully listen. If you are that desperate I would go for a cheap walkman. Cheaper, easier and less chewing on batteries
R.
thank you i was just asking
woot internet radio :P
Well there is another alt solution for that...
Realplayer for Nokia 7650
yes internet radio is all you will get on this thing, thats why I said it :P
^5 to OsirisMedia 😃 8)
whats ^ 5 mean?
i think it's a high five
so realplayer actually works for internet live music???
i suppose you would have to remove all other programs and it is so big and you need a gprs connection... i will try it .. any simple instructions or hints on how to setup the programe and get started??
will it work via wap
It depends on what WAP connection! Some dont let you download large amounts of data! However, the quality will be low as well, but I think it is possible, but useless!
