Dial Up Settings.
2 replies · 1,443 views · Started 12 September 2004
Hi, how can i use my dialup ISP on 7610? what are the settings? what do i write the dialup number as and all? in windows in the dialup box i write 13133111 (im frm pakistan) do i need to write the city code or sumthing before that? my proxy is proxy.multi.net.pk.. port number is 8080.. i have tried but it says 'connection error' can somebody please help?
[QUOTE=zainman]Hi, how can i use my dialup ISP on 7610?
I have the same problem on a 6670. The phone will not innitiate a data call (analogue or ISDN110) and fails to error code -3002. :frown:
Problem solved. Use an ISP that:
1. Dosen't mind you dialling from a mobile number...Most resrict their service to land lines.
2. Will accept data calls.
All should now be OK bar the cost of the datacalls!
