files receiving problem...help??
1 replies · 1,678 views · Started 12 September 2004
Hi 7610 owner is it true that all file received from other hp will be directly save in our phone memory??Therefore if the files send to u is bigger than the phone memory we cannot received it????Can we change the setting therefore file received can save directly to the mmc card instate of phone memory so that no such thing will happen ??? :con?
rolandy wrote:Hi 7610 owner is it true that all file received from other hp will be directly save in our phone memory??Therefore if the files send to u is bigger than the phone memory we cannot received it????Can we change the setting therefore file received can save directly to the mmc card instate of phone memory so that no such thing will happen ??? :con?
Hi, i'm fairly sure that is correct. Someone feel free to correct me if i'm wrong. I dont think you can choose where to save things when they are coming into the fone, they're all saved in the inbox, you can move them from there later, but initially they go to the inbox (which uses fone memory)
