Application wont work
1 replies · 1,289 views · Started 13 September 2004
Hi wonedr if anyone can help me?
Had a problem with my Nokia 6600, well with the memopry card, so followed advice given 😮 and ended up re-formatting the card, which I didn't really want to do, but at least the phone works now
BUT!!
Ok so it works, but I wanted to get one of the "Try and Buy" applications that were offered ie the video one that lets u link the short vids together? (does that make sense?) well anyway I purchsed it off the Symbian site and thought great now all i have to do is get it installed on the phone.. still with me? well I bluetoothed it to the phone...it suggested that as I no longer had any data in the "try and buy" folder that I would need to install the Application Key Manager file firstly and then the UVSM application... well this I did....and now I'm, stuck!!..how the hell do I get it to work on the phone.......It's showing in the "application manager folder" of the phone and stored in the memory section (not the sim) but I can find no option to actual get the Bl**dy thing to work!! 😡
Any suggestions??????? anyone :con?
