Infosync takes a look at the 9300
4 replies · 2,190 views · Started 13 September 2004
Equipped with a QWERTY thumbboard, the 9300 is slightly more friendly in the text input department than the 9500 as its thumbboard is just a tad narrower. It's not much, but every little bit helps for a solution that in the past has typically appeared too wide for thumb typing, and too small for touch typing.
Nice!The 9300 just scored some points over the 9500 in my book.
