Nokia 7650 hanged up... Need help... A.S.A.P.
8 replies · 2,446 views · Started 02 October 2002
Hi guys from all over the world... can you help me with my problem with my Nokia 7650... I'm too excited and installed a lot of softwares, games, and ringtones... and it hanged up... how can i make it open again...
Oops.. Seems you encountered the first major bug in the 7650.. With firmware revision 3.12 the phone will hang and refuse to boot if the memory if full ..
safest way out is to take it to the service centre.. they might even upgrade the firmware for you while you are there.. but they will definitely solve the problem...
unsupported ways include manually resetting the memory and contents via an undocumented feature .. seach the forum for 'reset' 'memory' ..
But I advice you to take it down to the NSC.
Hi jerrylimchua, have you already check the *#7370# which perform a reset ???
Domi.
*#7370# is very useful.
It perform a reset but can I say that it will reformat the C:\ to the fresh?
What are the other key like
*#7370#---reset(of what ,on what)
*#0000#---firmware version.
how about IMEI?
format c:\ to the fresh?
Oh dear oh dear... seem like you need to visit the Nokia Care Centre.
Suggest that you upgrade your firmware asap.
