Assign functions to navigation (joystick) keys
11 replies · 5,270 views · Started 14 September 2004
Hi. I recently got a 7610 and have 3 questions:
1. If a play a ringtone with the memory card icon next to them, they standard is very poor and they seem to pause every few seconds. Is this a problem with my particular fone?
2. is there a way to set a period to automatically lock the keypad as does the 7250. I know there is a way to automatically lock the fone (which requires your pin code to continue) but this is not what i want.
3. is there a way to define functions to the navigation (joystick) keys. Just the "select" key is assigned which brings up the contact list, but is there a way of defining functions when pressing the left/right/up/down keys whilst in standby mode. (Eg. on 7250, left creates a new text, right goes into the calendar)
thanks all!!!
hawkerpaul wrote:Hi. I recently got a 7610 and have 3 questions:
thanks all!!!
1.-> Probably
2.-> Try AutoLock, post back if you cant find it.
3.-> No. Organise your menu so that you can use the number keys to act as short cuts.
Good Luck 😊
AP_7610 wrote:1.-> Probably
Good Luck 😊
Could you tell me where auto lock is please??? 😊
So isnt anyone else getting the same problem with their ringtones stored on the card?
go into the ringtones and select any of the .amr files with the card icon next to it.
on mine, the quality is very poor, and playback pauses briefly every few seconds.
does anyone know of any applications that can assign functions (eg. write new text message, calendar etc.) to the navigation (joystick) keys.
thanks.
Yes - if they are MPS's, it a know problem with stereo MP3's try re-encoding them to mono.
Also if you use a cheap MMC some are slower than others.. apparently.
Will
I remember there was a program where you can assign certain apps/functions to the joystick/d-pad keys. Forgot the name ...
I'll come back when I find it again
I also get same problem with my 6600 phone. There is not short cut function at standby model, but I heard Psiloc Task Manager can set function to that. I have not tried yet.
i have use task manger in nokia 660 but it slow down the set
gallery which took 2-3 sec took 15-20 sec when task manger is active
rest it is very nice application
it must inbult.
Vicky wrote:i have use task manger in nokia 660 but it slow down the set
it must inbult.
i request u to not use task manager
jazzy1 wrote:i request u to not use task manager
Why u r making request that not to use task manger?
just use the demo and if he/she feel comfortable then he will buy?
see www.psiloc.com for demo.
