Removing temp, help & installation files to increase mem
1 replies · 3,032 views · Started 02 October 2002
I remeber a trick I picked up from these forum's with my 9210. You could activate the file manager and remove old installation files (*.SIS, although these had to be replaced when uninstalling an app) the Nokia help files, and the tempoary files which were tucked away.
Anybody know which files it is safe to remove on the 7650?
hrmm I dont think the 7650 has naything like that yet, but would be very useful
But I dont actally think the install/help files ar eleft behind on this one, because I isntalled a HEAP of software on my previous 7650 handset and used filemanager to explore the system and never really found large traces of temp files etc.
