SeleQ not woking properly on 7610???
4 replies · 3,182 views · Started 14 September 2004
Hi i had install SeleQ v1.65 and i found that when i am in the program i cannot run the Options key and it state Feature not supported.
Does anyone got this problem???
you can't use the options in 7610..
you can only do whatever by the (circle) button in the middle
option<----- is not supported only..
other features work without problems 😃
i was also getting the same problem thatmy option key was not working or else supportable by nokia7610
u can use Fx Exp it can help u.
