Hi, my 6600 seems to hang quite a lot when using switching between aps and using the green phone button for making calls to my last rung number (I get message Log Aps Closed).
Someone has suggestted a firmware update may help, but how do I check which version I'm currently running?
many thanks
Aeis
Aeis wrote:Hi, my 6600 seems to hang quite a lot when using switching between aps and using the green phone button for making calls to my last rung number (I get message Log Aps Closed).Someone has suggestted a firmware update may help, but how do I check which version I'm currently running?
many thanks
Aeis
*#0000# - is this every app?? Not sure its the fw rather than the app itself.
Thanks for that.
It appears to be in more than 1 application, bothLog and SMS apps do it.
This is the 2nd phone I've had which has acted the same.
Also my Jabra BT250 Bluetooth Headset does not ring my normal tone through the headset all the time. Not really a problem but rather just a pain.
Hoped the firmware upgrade might help? 😃
It may well do - not all phones act the same regardless of fw - bit like computers - some develop bugs and some dont - millions of bits of information and just 1 can cause problems - technology - CANT LIVE WITHOUT IT, CANT AFFORD TO SMASH IT TO F*#K EVRYTIME IT UPSETS YOU.
