Does anybody know if it�s possible to set different colors for the Circular Graphic�s sectors?
Thanks!<font size=-1>[ This Message was edited by Manowar on 2001-12-03 1731 ]</font>
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2001-12-03 1353, Manowar wrote
Thanks!
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Press 'Select Object' in Graph mode, Select 'Series n', select appropriate Series and change color for it?..
It doesn�t work on Circular Graphics. If you set one color, the whole circle will change.
That was the reason of my post ![]()
Regards
I would like to add a list of hours in Sheet. For instance 2030hrs + 3015hrs + 4015hrs = 91hrs. I find that the moment I enter any figure more than 24 hrs, Sheet treats the figure as text does not compute it. The only way out I have found is to convert the hours to decimal format and then add them but this is not ideal. Can anyone suggest a better way?
Ps the Psion 3a Sheet could add hours directly, I wonder why they omitted this useful feature from the 9210 Sheet.
