the gprs connection is on "when needed" but still my phone always connects to gprs whenever I when I turn it on or I receive a call, sms. what shoul i do??? Pls help..tnx!
Help on gprs connection for 3660
Red14 wrote:the gprs connection is on "when needed" but still my phone always connects to gprs whenever I when I turn it on or I receive a call, sms. what shoul i do??? Pls help..tnx!
Is it G with or without the box?
I've setup my device to use it always, since our network supports it.
the "G" icon appears everytime the GPRS connection it's available
the boxed G icon just appears when sending emails or browsing a website.
I believe that the G itself just means that, "available" and does not means any extra cost while in standbye
cya
CasperVD wrote:I've setup my device to use it always, since our network supports it.
I believe that the G itself just means that, "available" and does not means any extra cost while in standbyecya
Exactly my point for asking.
Kamalayan wrote:Is it G with or without the box?
it's just the G w/ slash n w/o a box,appearing in the antenna icon.it appears everytime i make or have a call or send or receive sms.pls help just bought my phone last sat., i dont know much about this phone.
As CasperVD & Kamalayan have just explained:
The G on its own means that GPRS is available but not being used.
The G with a box round it means that GPRS is in use.
The G with a slash through it means that GPRS is available but cannot be used at the present time because (for example) you are sending or receiving an SMS.
So the only time to have concern is when you see the G with a box round it!
GordonShowers wrote:As CasperVD & Kamalayan have just explained:The G on its own means that GPRS is available but not being used.
The G with a slash through it means that GPRS is available but cannot be used at the present time because (for example) you are sending or receiving an SMS.So the only time to have concern is when you see the G with a box round it!
o...tnx a lot!
