Unlocking MMC Card on 6230
17 replies · 36,865 views · Started 16 September 2004
I know that this may not be the correct area or the fact that you may not even be able to help!
But if you dont ask you dont know!
Ok i have a nokia 6230 and i've had the phone replaced but have keeped my original nokia multimedia card the problem is that it beleves that it is password protected!
I have tryed putting the card in another 6230 but to no success i have aslo put it into a card reader to see if i can read it and again i can't see it! it just hangs the card reader.
i have been reading your forum to see if anything on her will work but i can't seem to get the Fexplorer to work on my phone assume it not supported!
i would very much so like to retrieve the data on th card has any one been able to do a unlock MMC on a 6230 and if so how was it achieved!
I am not brilliant at doing this kind of stuff so if anyone can help a step by step guide to go with it would be really apperciated aswell
thank you for taking the time and i hope that you will be able to solve my problem!
Any one know how you can unlock a mmc card that is barred with a password. Basically i never set a password on the mmc card but it ended up asking for a password ne way while i was listening to music on the phone
It's very simple😊))))
Need only a symbian phone
1: Use any efile manager like SELEQ 1.65
2: Open SELEQ 1.65 and go to Root C:
3: Options and FIND, write MMCSTORE press OK
4: Send this file by Bluetooth or Infraread to your PC
5: Rename the file MMCSTORE to MMCSTORE.TXT
6: Open the file and the password off the MMC are there
Enjoy....
airbilly wrote:It's very simple😊))))
Enjoy....
Is seleq working on the 6230?
I uploaded it to my phone and I can't find it anywere in the menus
I have a Nokia 6230 with a 256 mmc card in it. Suddenly, it became password protected. Anybody know how to unlock it? Please heeeeeeeelp...Where can I get Seleq 1.65 from? Please and thx very much
hello i cannot unlock my card. i've done the mmc store thing and the only numbers i can see in the text are 70000 and this still wont unlock it. please help!!!
The One And Only Solution To This Problem!!!!!!
I Don't Know How It Came To Me But It Is Very Simple
Just Cover The Last Pin That Is Closer To The Cut Edge Of The Card With Some Clear Tape And Voila!! The Card Is Not Write Protected Anymore And Works Just Fine!! I Tried It In A Card Reader And In A Nokia 6230!!!
Hope That Solved Everyone's Problem
Have Fun With Your Nokia
I tried that on my 32mb mmc card that come out of my 6230 and no joy, the panasonic SD formatting software still says the cards write protected..! is there anyway to force format a mmc card on a pc card reader, or will I have to do it in the phone.
ta,
GORTSILAS wrote:The One And Only Solution To This Problem!!!!!!
bikerdude wrote:I tried that on my 32mb mmc card that come out of my 6230 and no joy, the panasonic SD formatting software still says the cards write protected..! is there anyway to force format a mmc card on a pc card reader, or will I have to do it in the phone.
ta,
none of these mentioned ideas work for unlocking my MMC on 6230....anything else please....
Guys the 6230 isn't Symbian, so you can't install seleq on it. You'll have to get a Symbian based phone, install Seleq or FExplorer and then follow Airbilly's tutorial on how to read the MMC password. I've tried it on my N-Gage and it works fine.
Enjoy....
i just wanna ask 1 thing
is it work if i have format the phone?????
'coz i've tried to find @ my formatted phone the "mmcstore" folder and it isn't exist..
pls reply 'coz i've hanged up w/ my locked mmc :frown: :frown: :frown:
sorry 4 my english :tongue: :tongue:
i hope everybody understand what i mean by
If the phone is reformatted, then the mmcstore file is gone and unrecoverable.
If you have both forgotten the password and lost the mmcstore file, then for any practical and economically viable purposes, the card is wasted.
hey guys pls help me by saying which software is used for unlocking the memory card from the computer(i mean to format from the computer not from mobile) please helpppppppppppppppp
flex869 wrote:Any one know how you can unlock a mmc card that is barred with a password. Basically i never set a password on the mmc card but it ended up asking for a password ne way while i was listening to music on the phone
Plz someone help. Ive got probably the same probs as the others on here, ive got a 1GB kingston mmc card, i changed the battery yesterday and the card (which has a adapter-like snap-on half joined on to it) fell out. I replaced it and it wanted a password ! It seems to have shrunk the size also... it was 1GB, but now - in the memory options - it has the size listed as 0KB ! Is it just like that all the way up to the equivalent of 1GB but in KB ? It wasnt before, thats why im curious.
Thanks for any help or comments received.
Carl:con?
