PlinkyKev,
I have installed the beta of Aquacalendar for Series 60 (which you should take a look at if you haven't already - great Calendar program) but when I try to add a link to the app in my Now screen I find that it doesn't appear as an option on the installed applications list.
Everything else appears, including the Java apps. Is there anything I can do at the file level to make Aquacalendar come up on the list?
Thanks and regards,
xerxes
Is the application installed on MMC or C drive?
mobilewonder wrote:Is the application installed on MMC or C drive?
I got firmware version of 14 June and in way random apps and games installed or on SD or on C I can link to Now! But no all! Then, no depends on installation is on SD...
I hope that this medium/heavy bug be resolve on this first firmware update...
It's installed on C.
The problem actually went away when I removed the old beta and installed the new version but I'd still like to know why this problem occurred in case I see it again with a different program.
