dears
where i can find ( Series 60 Theme Studio (for Symbian OS) v. 1.14)
i try nokia forum site : http://www.forum.nokia.com/main/1,6566,034-301,00.html ,
but i get an error when i try to download.
please help me.
thanks a lot
dears
please help me.
thanks a lot
AFIK, the developer forum is the only place to get it. If it doesn't work atm then just try it again later.
Hi Emoemo,
I had the same problem as you with the Nokia Forum Site so I found this site instead and it
worked just fine. It�s just to register and then you can download the things you need.
http://www.sourceo2.com/O2_Partners/Nokia/Toolkits.htm?CategoryName=Series%2060
(Scroll down and you will find Nokia Theme Studio)
Hope this will help you.
Take care, Starlet
It won't download from sourceo2.com ..
This message appears:
Nokia toolkit
Please confirm your acceptance of the Terms and Conditions below.
Once you have done this you will be able to download the selected file.
Nokia RSShttp://ncsp.forum.nokia.com/Copyright 2002-2003, Nokia CorporationNokia CorporationNokia Content Syndication RSS Feeddaily12004-09-10T08:18:15-06:00Nokia 3D Animation Toolkit User Guide v1.1http://ncsp.forum.nokia.com/download/?asset_id=10266Nokia 3D Animation Toolkit User Guide v1.12002-07-02application/pdf10266English3DMobile Entertainment SolutionsForum Nokia2002 NokiaNokia_3D_Animation_Toolkit_User_Guide_v1.1.pdf285 kB10266Document1.0
And then you can click Accept / Cancel !
When you click Accept, the window just close, you don't get then file you are trying to download!
What do i do? :s ..
Which Explorer r u using for Internet
They work fine in my microsoft internet exploser v.6.0.
Check you don't have your popup blocker on - that's exactly what happened to me before i switched it off for that site...
