Nokia 6600 Blank Screen With A Difference
2 replies · 2,352 views · Started 17 September 2004
I know a fair bit about Nokia Symbian, however this has me stumped.
Im in the UK using an O2-UK SIM card, the screen goes blank after 2 to 3 hours. Nothing too out of the ordinary so far. However when i put in my Orange SIM card my mobile operates perfect, no black outs.
Obviously the answer is simply to chuck my O2-UK SIM and simply use Orange, but i like the tarriffs and simply, why should i chuck my O2-UK SIM "if" it can be sorted.
Has anyone else came across this same problem? And does anyone know a way around it?
have you already tried to buy a new O2-UK SIM?!
have you already take a look to see if the SIMs are equal in their caracteristics?
Martin77 wrote:I know a fair bit about Nokia Symbian, however this has me stumped.
I had problems with my O2 SIM so i emailed them and got a new SIM card sent out (with the smae number).
I would also suggest checking the warranty of your 6600 - may need reflashing.
