To: KAMALAYA
1 replies · 1,153 views · Started 17 September 2004
Kamalayan, I'm from the Philippines too. Globe ang network ko. Dati naman nakakapag-send ako ng MMS. Halos daily nga ako ngayon nagddownload ng MMS settings both from Globe using GO N6600,,1234
Wala talaga. Aksidente lang kasi pagkaka-erase ko nung flash memory (C😊 sa file explorer. Favor naman, if 6600 din phone mo and you have File Explorer, pakitingin if you have any folder in C: tungkol sa MMS settings & MMS viewer. Thanks a lot
NEEDING HELP!!! wrote:Kamalayan, I'm from the Philippines too. Globe ang network ko. Dati naman nakakapag-send ako ng MMS. Halos daily nga ako ngayon nagddownload ng MMS settings both from Globe using GO N6600,,1234
What made u think that im the only filipino here? Why did u delete the entire c (?) How the hell were u able to do that? Files in the drive c: are system files specially those in the systems folder, never ever do that if you dont want your phone formatted. What you could do in my opinion is download the MMS/GPRS configuration from globe again by keying the keywords u mentioned then save it if u didnt moved it in a special folder before. Move the configuration files to some folder so that you would be able to restore if youll be doing a format again in the future. If that doesnt work and your phones Fu@ked up you may have to format. If only the mms service is unavailable then what I first suggested could be the solution. You may also want to ask Globes service 730-1000 how to resolve this.
