7250 To 7610
2 replies · 1,532 views · Started 17 September 2004
Just upgraded my 7250 to 7610 and am looking for an easy and quick way of moving my phone book.
Can't upload using USB and Nokia suite, can't infrared.
I don't really want to copy to sim as the details get split and shortened.
Would a phone shop be able to do :con?
The only way is saving the contact list to your computer PC Suite (via infrared or dku-5 usb) and then transferring to the 7610 (via dku-2 usb)
That's the only way (apart from the SIM card way)
nk_au wrote:The only way is saving the contact list to your computer PC Suite (via infrared or dku-5 usb) and then transferring to the 7610 (via dku-2 usb)
:icon14:
Thanks for that, had phoned a couple of phone shops and got the same info. So spent about 3 hours on and off putting in the numbers manually 😡
Cheers
