I don't know how to get my pictures from my phone to the internet. Is there a way to do it without having an email account? I do have access to the internet from the phone.. and I tried bluetooth but it couldn't find devices ?!?
btw, i'm using at&t wireless.
Sorry I'm a n00b. D:
to clarify, will I need a blue tooth device to hook up to my computer in order to transfer pictures, videos, and games back and forth??
1) you can use PC suite to connect your phone via bluetooth. for details about that, you can search the forum
2) when u said "internet on the phone", i am assuming u are meaning GPRS. You can upload the file you want on the internet (computer) and download the file from GPRS. Charges as per operator.
Rohit
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3311&item=6324962971&rd=1
would something like that work?
I tried looking but I couldn't really understand what you mean by PC Suite.. thanks.
1) The item on ebay which you posted seems OK - I mean that it seems OK for using it as a bluetooth device for your computer.
2) PC Suite is the software provided in the CD you get with your phone. If your phone has Blutooth/Infrared/ connection to your computer, you can use PC Suite to install new software,save settings, import contacts from another phone...etc.
3) After you install the drivers for your bluetooth port/IrDA (infrared) port, you can use MRouter [MRouter is a part of PCSuite - it establishes connection with computer to phone via bluetooth/irda/etc] to connect your phone to your computer[MRouter shows up on the taskbar as two plugs not connected - something like that- when you connect your phone via infrared/bluetooth, you double-click on the two plugs thingy. It'll show you something like Cable which is not ticked. If you are using IrDA/Bluetooth it should show up. Whichever connection you have with the phone, you click on that. The status should be connecting... finally connected. Then you open PCSuite and experiment.]
Hope this was helpful
Rohit
