system error!
1 replies · 2,158 views · Started 18 September 2004
i'm trying 2 edit my 128mb mmc using suse linux 9.1 kernel 3.2.1 via usb cable data and it work. I'm trying 2 delete my mp3 files (the mmc is password, but nothing's change) then replace it with new songs from cd (copy+paste), and it work too. Last, i'm trying to rename my slauncher's skins (*.skn) (the skin i've got it from being d/l it from internet) and it work too. After i'm finishing, my phone starts getting msg "system error!" but my n-gage it's still works include the game n apps. But one day after that, i can't remove my application (tools+appmgr). I'm getting the msg again and the system is hang. I'm trying 2 push the red phone icon button, and it work but the appmgr it's still hang. I'm trying 2 edit the file using "file" apps and delete the installed lists, it deleted but i'm still can't install a new apps. Then i'm tring to delete *.ini files, and it's say "file is corrupt" and it cannot be delete. I'm trying to edit again my mmc using windows xp, copy the important data to hd, format my mmc then put again the data, then error is getting big. Ican't play games and also get the msg, why? :frown:
Seems like this has nothing to do with your MMC but is more likely a problem located on C drive (internal memory)
Make a backup of your contacts, calendar, etc and format your phone (search the forum and the support section for the how to on resetting your phone to default settings).
