Hi, can anyone pls advise mi how to safe my music on a memory card of Nokia 6600 :icon14:
Memory card
ladieslovescool wrote:Hi, can anyone pls advise mi how to safe my music on a memory card of Nokia 6600 :icon14:
like would please tell me in detail.
Easiest way is to buy a card reader. You just then transfer the music files from your pc to the card. You can also send via bluetooth/infrared any they will appear in the inbox. You can then save them once opened (I think) or use fexplorer/selecq to move them.
The easiest way is to use BT and PC Suite..
jtavares wrote:The easiest way is to use BT and PC Suite..
don't u think it take plenty of time to transfer via bluetooth or Ir.
if u r transfering 10 Mb of data. Card reader took less then 20 sec.
and bluetooth will take more then 7-10 min(approx) or more.
But you have to poweroff and poweron your phone...
You have to remove the battery and the MMC...
And after all... Windows or your drive can still crash MMC file system ...
Think about this... 😊
Better wait for few seconds than have a FS crashed ...
my mmc is corrupted... how can i solve thie problem? i need help... pls.. eamil me at [email][email protected][/email]..
Just Format Using Option In Memory In Extra.
