occasionaly troubled with bluetooth
1 replies · 1,451 views · Started 19 September 2004
the bluetooth is activated, but can't get any connection from anywhere, cpu nor other other bluetooth phones. when i try to restart the bluetooth(turn it off back and on again), it gave me something like, "unable to control bluetooth device" once, then i click it again, it work normally after that. but this is happened to me lots of time, it's annoying, i have to restart the bluetooth anytime i need to connect to something. does anyone else experience this too?
nerofire wrote:the bluetooth is activated, but can't get any connection from anywhere, cpu nor other other bluetooth phones. when i try to restart the bluetooth(turn it off back and on again), it gave me something like, "unable to control bluetooth device" once, then i click it again, it work normally after that. but this is happened to me lots of time, it's annoying, i have to restart the bluetooth anytime i need to connect to something. does anyone else experience this too?
Sounds like the same problem I'm having on my QD and which I'm trying to get some input on
HERE.
So far I haven't had any decent response :frown:. As I typically turn off bluetooth while away from the PC to safe battery-time, it is such an issue for me for synchronizing, but ... as it also drops with my bluetooth headset unless you are actually in a call, it makes the headset unusable (by the time there's and incoming call or you want to use voice dialing with the headset, the QD's BT will have given up).
