help with 3650 please
3 replies · 1,478 views · Started 19 September 2004
hi
ive read that you can install apps inn 3650 with a cable or bluetooth or so. Ive downloaded som files and i have also tried to install them with my pc because i have a pc in which you can stick in the memory card. how can i install them with this method. Ive tried it with nokia suite but i doesnnt work because it only works with cable bluetooth or infrared. cann someone help me please???
I got FExplorer installed. If you have it once you can place the *.sis Files on the card and put it back in your mobile. Then install them in FExplorer.
The only problem now should be to install FExplorer. Maybe you can download it per GPRS.
Waris82 wrote:Can You Help Install FExplorer please and email it to me at [email][email protected][/email] thx and can u write it in steps and can you attach the files thanks.....
bye
Search the forum, it has been discussed to death already. With that you'll also learn lots of things. 😉
