Help!!
3 replies · 1,161 views · Started 19 September 2004
i recived a picture message from sum company and it saved to my mmc now i cant see n e fing saved to my mmc in the gallery and wen i try n look at my mmc in FExplorer i sez "App. Closed Fexplorer!", wots happenen? has my mmc broken? what shall i do? any kind or help would be great as it is much needed
thanks
Blimey thats a new one!!!
I would suggest formatting your mmc and starting again as it sounds as tho the damage is already done!
Must have corrupted the mmc!
do you have a card reader
if so try trying to delete the file on your pc
if it doesn't work you'll have to format
