Magic Profiles Pro is the best utility for Sony Ericsson P800/P900/P910 devices that allows you to manage various phone profiles, to enable a full call management, to set profiles according to your location in GSM network and much more as system sounds and Bluetooth control.
Using Magic Profiles Pro, you will never experience any problems enabling, for example, a silent mode for night time or meetings, a loud mode for an outside or car driving, and much more, any imaginable alert settings. You can bind these profiles not only to 24-hours' grid, but for workdays and holidays, defining rules and exceptions. Your smartphone will automatically switch between the profiles offering a comfortable work with the device.
Our handy call manager will give you the full power of controlling incoming calls. You can create white and black lists with any corresponding actions, from rejecting a call to forwarding, sending SMS and more.
With various profiles, you can control the most of phone features in just one touching of your smartphone's screen. Change rings, sounds, messages, vibrations, sound volume of ring and talking, at one moment! Using this application you can create any number of profiles and switch between them instantly - in the same way as on an ordinary mobile phone.
Magic Profiles Pro understands your Calendar's appointments and follows them. Now and forever you can forget all about these manipulations with ring volume, melodies, vibrating alerts, etc.
At last but not at least, Magic Profiles Pro can determine your location within a GSM network (using cell ids). You will never make a mistake enabling profiles being at work or at home, because Magic Profiles Pro always knows where you are.
