Why i can't send file in size 5 mb via bluetooth, alert(memory is full) .
is my spec memory :
drive C: 2.61 Mb
drive D: 6.3 Mb;
drive E(mmc): 90 Mb
Bluetooth
TO the phone or FROM thee phone?
to the phone its imposible because the massages are stored in C drive...
from the phone (??) - instal fw13 😊
What happens is that your sending files via your mailbox which is located at C: drive. Do one of the ff:
a) Install a program (or is it just a patch?) called msdriveE.sis. That will make your mmc the default mailbox.
-haven't tried it yet, and if you don't know what you're doing, it could fuck up your phone.
b) Make a serial connection to your pc, you can do this by right clicking the bluetooth icon from the pc's system tray, >quick connect>bluetooth serial port. *But you have to install the Siemens data suite first, and make sure that mrouter is active.*
-When succesfull, you can easily drag and drop files from windows explorer to your phone easily.
Oh, one important detail- you should have windows xp installed.
LynMan wrote:TO the phone or FROM thee phone?to the phone its imposible because the massages are stored in C drive...
I have instal fw13
