3660 Nokia PC Suit for not working
8 replies · 5,381 views · Started 21 September 2004
I got an Irda and install Pc suit, It was working fine till yesterday. Now when I tries to connect my 3660 the mRouter respond accordingly in windows XP, files could be transferred from link manager, but when i starts PC suit or want to run any *.sis file the system responds divice not connected.
Can any body help me?
(1). mRoute is working in system try accordingly.
(2). PC suit could not detect the phone, but was working previously.
Have you tried running PC Suite, selecting Control Panel, then Connection, and making sure that the correct connection has a tick next to it?
raja007 wrote:I got an Irda and install Pc suit, It was working fine till yesterday. Now when I tries to connect my 3660 the mRouter respond accordingly in windows XP, files could be transferred from link manager, but when i starts PC suit or want to run any *.sis file the system responds divice not connected.
Double click the mRoute icon on the system tray, then tick the 'infrared" connection, wait for the status to change to "connected" before starting the PC Suite. If still doesn't work, check your infrared/Irda controller if you have the latest driver.
Cheers.
Yes, I had checked the connection, the file can be transferred through standard windows methord: Browse the file and send, then recieve in 3660 inbox.
But when I open the PC suid to directly access the folders in 3660, it shows no 3660 is connected.
Can you say, what is wrong with my 3660?
Problem: I install some .sis file and after that my phone don't recognize letter, only numbers. System says allways System Error
raja007 wrote:Yes, I had checked the connection, the file can be transferred through standard windows method: Browse the file and send, then recieve in 3660 inbox.
The mRouter icon is different from the wireless link icon on the system tray. This has happened to my 6600 connection before, there is just a few seconds delay with the mRouter before I could establish the connection so I waited until it says "connected", but the stardard windows method is already working.
If still doesn't work, check if you have the latest PC Suite version.
Cheers.
You was right, but i did with PCSuit restore and phone is working now properly.
Thanks anyway.
Change the transfer rate of your PC IrDA device from 115200 (default) to 57600. It will do the work.
