New Firmware impossible to Install
24 replies · 4,857 views · Started 21 September 2004
Hi
I have purchased in Spain the Sendo X. It comes with the 1.13.3.1 (17 May) version!!
I�m trying to update the phone�s software because the phone is almost unusable (very poor reception, veryyyyyyyyy slow and so on).
I�m able to do backups, install programs ...etc through the Sendo PC connect, but when i put the phone in download mode to start the firmware update, the PC doesn�t recognize the Telephone. In thi moment the cable indicator in the phone is green.
I�ve tried to make it work in two different PC (with windows XP) without success.
Please.... i need some advice/help ... i don�t have more imagination to try to make it work 😞((((
greetings from Spain
Javier
have you made sure you downloaded the correct s/w because if you download and try to install an uncompatible version it just wont work.
Check the sales pack against the one mentioned on the sendo websites download section and make sure it matches.
The sales pack is usually list on the label behind the phone (when battery is removed) on the 3rd line.
Hi!
Thanks for your fast response...
In the phone as you has told, i see "Made in Netherlands, 8Y0H-02170-2X000"
and i have downloaded the "Spanish 8Y0H-02171-0X00 v1.56.2.2"
So , I think i�m trying the right version �?
cheers!
Have you installed the drivers, these are different drivers for the firmware than the pc connect drivers
I have unistalled everything before the sendo update. And when i connect the phone and windows asks for the usb driver for the phone, i install the one that comes with the Sendo Update.
Your phone = 8Y0H-02170-2X000
Firmware update = 8Y0H-02171-0X000
Therefore not compatible firmware.
Plus your current s/w is VERY old, where did you buy the phone from?
from an official shop from Movistar (the Spanish carrier that is the only one that sell the sendo X in spain).
I�m starting to be very sad with this.... Anyone from Sendo can take a look a this post please!!!!!
Thanks!
morph wrote:from an official shop from Movistar (the Spanish carrier that is the only one that sell the sendo X in spain).
Thanks!
Please also check the code from the label under the battery. If you still have this problem, please log it with the Sendo support system, here:
http://www.sendo.com/support/index.asp
PS: Other users... you might want to log things this way too. ONE item per log however, for ease of progress...
i also think his version is too old for the current firmware update.
hopefully sendo support engineers can fix your phone !
Hi!
I have a question opened in English since yesterday in Sendo under javier.juan@..... login .
In the label below the battery i can read:
SENDOX EF SNDX00
MADE IN NETHERLANDS
8Y0H-02170-2X000
FCC ID: P6P8NDX00
is there no chance to make an old update to catch a version that is able to be updated with the last firmware?
Thanks!
morph wrote:Hi!
SENDOX EF SNDX00
MADE IN NETHERLANDS
8Y0H-02170-2X000
FCC ID: P6P8NDX00
Thanks!
Right! Got the answer. Your version (02170) is for Telefonica. They have not approved the firmware yet, so it is not available for release. When they say "OK", it will be on the download page.
Regards,
pk
Thanks Pk, this is the worst news you could give me! 😊
I have called the Movistar shop where i bought it yesterday (Movistar is the mobile label from Telefonica) and they have told me that they can do nothing. They say that the phone works and they can�t return my phone because is not faulty.
I also have asked the Sendo�s Service centre located in my city and they don�t know nothing about this.
Knowing Telefonica...perhaps the software update will be never avalaible...
Does Someone want to buy a brand new Sendo that is almost not able to receive or make calls....? 😞(((((((((((((
I know this is not a Sendo problem...but this makes me feel sad. I was waiting for this phone around 6 months and now....
Thanks all for your support
Javier
For Plinkykev,
So Telefonica hasn't approved the firmware yet!!??
I'm from Spain and I ordered the phone 2 weeks ago, but they don't even know when it will be available.
Do you think it's because they're waiting for the firmware approval?? Is Sendo sending (wow, now I get what Sendo means!! haha!!) any unit to Spain... or you're waiting for telefonica so you can send'em some Sendo's with new firmware???
I would really appreciate that you could respond to this questions.
Thank you in advance!
Manontehmoon: I asked for the Sendo X in a local shop in Madrid. I got it in my hands only 24 hours later....but.... you can see that It�s not recommended 😊
It�s in Madrid, (Calle Fuencarral 86).
Un saludo (Regards)
Javier
WHAT!?!?!?!?!? You say it's not a Sendo problem?!?!?!?! FOR GOD'S SAKE!!! Of course it is!!! They have released a phone with an awful beta of firmware!!!
You can't blame Telefonica!!! I'm from spain (y me da igual de rabia Telefonica), but this is OF COURSE an actual problem of Sendo!!!!
Unfortunately it�s very usual to release phones with software bugs.... but in this case, Sendo has the key for my problems but Telefonica doesn�t approved it ( I think due to software personalization....).
If I�d worked in sendo for example i�m sure i could be able to fix it, but Telefonica is the only carrier who has this phone, so it�s the one who i must argue.
Manontehmoon wrote:For Plinkykev,
Firstly, Telefonica approved the ORIGINAL firmware, in your handset now.
Telefonica (and all other operators) were sent the new firmware to approve so it could be put on the download site. They all tested it OK and approved it. I do not know why Telefonica have not done it yet. I am sure it will be out very soon, don't worry.
This post will be a good reason to ask them to hurry up maybe!!
pk
download the netherland-version, install the netherland-version and after it, switch the language to spanich!
So it works!
Chriss
or perhaps they have already read this forum and realize that there are still major bugs and issues with the new firmware and are holding off untill a realistic firmware is released that addresses most of the problems
Just a thought
plinkykev wrote:Hi,
Regards,
pk
oh sorry, i don't read this post!
Hi!
I tried to download the dutch version (SendoXUpdate_8Y0H-28171-0X000_1.56.2.2.exe)
I have used the usb driver that comes with this version, then I select as Language Dutch to install, but i have the same error.
Did i miss something?
plinkykev wrote:Hi,
Regards,
pk
Plinkykev,
Would it be possible for you to publish a table that shows which version is for which operator?
That would probably help those of us who bought from abroad to download the correct version.
Thanks.
xerxes
Pk.. have you done something at Sendo about this topic? :P
since this afternoon in the download page of Sendo I can see a new link to a Telefonica Moviles download 😊))
Unfortunately is still not avalaible. Do you know more info? , sincerely, i can�t wait!!! 😊)
Thanks a lot!
xerxes wrote:Would it be possible for you to publish a table that shows which version is for which operator?
On the download section of the site, select the version you think you might need.
Then click on the "Release Notes" button below it. In there, the operator details are shown, under the country name.
morph wrote:since this afternoon in the download page of Sendo I can see a new link to a Telefonica Moviles download. Unfortunately is still not avalaible.
It is there on the list as I asked for the version numbers to be on the website, so people could tell the version they needed, and so stop you downloading the wrong one.
We are still waiting for them to say OK, so it is not there yet. We are chasing them!
Can anyone tell me which operator my phone would have been designed for if I bought a French Sendo from Pixmania?
