i got this apparcserverthread popup message every time i start my phone, and when i press the "ok" button, it just appears again, and keeps appearing all the time so that i am not able to use my phone.
pls tell me what to do, and if i need to format my MMC, please tell me how.
(i have no mmc reader, only data cable conected to my pc, i think i heard once that i can format my mmc by calling a number, but i do not know which...)
pls reply fast, i want to use my phone(just got it😊)
7610 appArcServerThread problem
one2go has an ArcThread something or other problem - you havent got that installed have you?
Nyxmorph wrote:one2go has an ArcThread something or other problem - you havent got that installed have you?
nope, i was installing some games when i turned off and on my 7610 and thats when i got this problem....i guess its one of the games....(sound doesnt work in none of them anyway...)
Uninstall them all? If u can get that far?
i don't know how much i am right but mostly appliaction when i install they give me this error and error Nht or like that.
i think many of the symbian software are not compatible with 7610
example is psiloc symbian software.
Nyxmorph wrote:Uninstall them all? If u can get that far?
nope, i can not get nowhere...
first thing when 7610 starts up is his app. closed message, even before entering my pin number...
and this message just keeps appearing, no metter how manytimes i close it...
i cannot even acces the menue...all i could do is write a naumber to call, but this is slow, since eych button i press, the next thing is this message....(thats why i would like to format mmc by calling a number)
bcoz 7610 isa new model model.
most softwares r not compatible with 7610.
plz wait softwares developers soon made for 7610.
format your phone and mmc and then try one by one
or make backu in computer then format if not atisfy then restore it again.
Vicky wrote:format your phone and mmc and then try one by one
yes, but how to format my MMC????
