i am planning to provide these phones to my sales staff but i need to know if the Sendo X smartphone can synchronize with outlook 2003 (bluetooth or docked)
as far as i can find info it will synch with previous versions but not with ms outlook 2003.
is this info correct?
BartB. wrote:i am planning to provide these phones to my sales staff but i need to know if the Sendo X smartphone can synchronize with outlook 2003 (bluetooth or docked)as far as i can find info it will synch with previous versions but not with ms outlook 2003.
No, it's old info. It works fine with Outlook 2003 (use it myself), over any of the bearers (USB/BT/IR). USB is the fastest method, then BT, then IR.
I sync with Outlook 2003 over USB several times a day.
The only thing that never seems to work is the email sync. Everything else is flawless and pretty fast.
plinkykev wrote:No, it's old info. It works fine with Outlook 2003 (use it myself), over any of the bearers (USB/BT/IR). USB is the fastest method, the BT, then IR.
thanks 4 the reply, will order some tomorrow, test some time and order the rest later
cheers
Bart
