Multimedia Converter and Intel P4 !!!
4 replies · 3,544 views · Started 03 October 2002
is it just me or is it a commen problem, I have 3 PCs here with Intel P2, P3, and P4, all of them can run the Multimedia Converter for 9210, but not the P4. I thought it was from the graphics card... mine is (Matrox G400 MAX), I've changed it to alot of kind of cards but it didn't work.
The strange thing is that the Multimedia Converter for 9210 on a P4 can work with sounds, but with vidoe clips.
Can I hear some comments from you guys/girls.
Thank you in advace to all 😊
P.S. When I have a stricker on my PC saying "Intel Inside", is it just a sign or a worning :roll: :P 😃 😉
I'm sorry but I don't quite understand what the problem is. I know I haven't had any problems on either a P3 or an Athlon XP 2000+ :P
When I try to convert any video clip using the MultiMedia converter for 9210 on an Intel P4, the program crashes....
duh..!
i have the same problem here :-?
i'm using a Pentium 3 Laptop and a Penyium 4 Desktop. the multimedia convertor doesn't work on the Desktop.
