SD/MMC card problems
4 replies · 2,246 views · Started 21 September 2004
Hello everyone,
I have the following problem: my Sendo X doesn't write to MMC/SD cards 😞
I bought a 256Mb SD card a few days ago and the phone recognizes the card just fine. However, when I try to copy files to it, or format it, it just gives me an error (generically called "System error"😉.
If I fill the SD card with files on a laptop, the phone reads them just fine (MP3, images), it just doesn't seem to be able to write to the card...
I went to the store and I tried different cards (as I already knew the sendos and nokias are a bit picky about certain brands of cards) but none worked: 256Mb SDs and MMCs and 128 and 64Mb MMCs.
Does anyone have any idea? I have the latest firmware and have formated the phone 2 times to no avail.
Thanks,
-- Electron
try to format your card using the format option on the phone, not on the pc.
also check if you got write enabled on your card. On my mmc/sd card i got a little button that i can but on write enabled/disableD.
Write is enabled on the card, I have verified it, and the error formating the card is when I do it on the phone.
The card works just fine on the pc, just not on the phone.
neuro wrote:I could be wrong, but I hear that S60 phones dont recognize SD cards....
My Sendo X does. Just bought a 1 Gig SD Card from Sandisk. Works perfect for MP3 storage (since I can't afford an additional iPod) and is fast. I read some reviews stating that SD cards are faster compared to MMCs and have larger capacities (MMC up to 512 MB and SD up to 1 Gig)
Sendo Y
