Can somebody help me to find english hand writing recognition for p800?
Hand writing recognition
What hand writing recognition it uses depends on what languag pack you have installed on the phone (unless you have the chinese version of the P800, in which case things are a little different). Go to the Global Support site for sony ericsson and try to install the Englush (UK) language pack.
What sholud I do if I have chinese version of p800? I installed language pack but it only changes language but hand writing recognition is the same, only chinese is available! Please help me!
If that's the case, you have a P802! Trade it for a P800...
Where can I see type of my phone? When I turn it on, display shows p800. When I format internal disk and i installation starts it starts in chinese but later I can change it to english. It means that i have two languages but only chinese hand recognition is there. What should I do? Please help!
Same here, I have a P802 so it's better wait for a third partie app, anyway I use "the pad" as an alternative, it works fine but it doesn't have "precognitive" writing but at least I can do handwriting.
