I just got the Nokia 6600 handset. I have infrared on my PC. Installed the PC Suite that came with the phone. No problem in installation. Switched on the Infrared connection on the handset, the connection was detected by the connector in the system tray. I opened the PC Suite and it asked me to enter a unique name for my phone suggesting "Nokia 6600"" as an example. I gave that name and I get an EConnect error telling me to please enter a valid name. I tried many different unique names but same error. What can be the problem. Can anyone help me?
thanks
Nokia 6600 PC Suite problem?
jhsurti wrote:I just got the Nokia 6600 handset. I have infrared on my PC. Installed the PC Suite that came with the phone. No problem in installation. Switched on the Infrared connection on the handset, the connection was detected by the connector in the system tray. I opened the PC Suite and it asked me to enter a unique name for my phone suggesting "Nokia 6600"" as an example. I gave that name and I get an EConnect error telling me to please enter a valid name. I tried many different unique names but same error. What can be the problem. Can anyone help me?
thanks
Goto connection see wot name u kept for ur phone under Bt settings use the same name...that's wot i think can solve.
Kaka wrote:Goto connection see wot name u kept for ur phone under Bt settings use the same name...that's wot i think can solve.
I found the solution. The trick was to let the app install in its default location(C: drive). It worked. Earlier I had installed it on a different drive.
Thanks anyway.
