Easy Typing Tool for SE P800/P900/P910 M A920/A925 released, Input+ v2.0
0 replies · 2,432 views · Started 22 September 2004
Brief Input+ feature list:
- Dictionaries and keyboard layouts for 12 supported languages available simultaneously
- User's dictionary with automatic word addition and word removal feature
- Memorizing Internet URLs, e-mails and phone numbers: once typed in, you can always bring it back using completion feature
- Two lines for completion, which give you an average of 10 completion variants at once
- Cut/copy/paste support
- Three window alignment options: up / down / stick to editor
- Toolbar can be hidden for saving screen space
Current language can be changed easily right in the virtual keyboard and you don't need to restart/reinstall the program. Just download your language pack, select it in the control panel and you'll be able to use it along with other language packs.
Input+ significantly speeds up text input on mobile phones. The program has ability to align floating-window control in different manner, by default closest possible to text in target field. Almost in all cases text editing occurs in Input+ floating window, so you can easily see the composed text. You can select portion of text in a field and Input+ will be bounded by your selection, so other text will not be modified. Two available buttons for scrolling through all fields within Input+ will be useful too, as well as cut'n'paste support.
Input+ has two lines for completion variants, which gives you an opportunity to find the needed word even faster than before!
If there's no some particular word in Input+' dictionary, just type it in and Input+ will remember it. This word will be added to your personal dictionary and you can later use just if it was in the base language pack. Words from user's dictionary can be removed either by one or all at once.
Input+ recognizes also e-mail addresses, URLs and phone numbers in your text and remembers them for future use. If you don't want Input+ to remember particular URL or phone number, you can easily delete it with two taps of a stylus.
Link to Input+ homepage
