Uninstalling apps on Nokia 6600
5 replies · 2,843 views · Started 23 September 2004
Use the "Manager" app that you can find in the menu, scroll to the program you want to uninstall, hit "Options" and select "Remove" from the menu.
The above, and many other useful pieces of information are actuall documented, believe it or not, in a booklet called the "User's Guide", which you should have received with your phone. If not, you can download it from http://www.nokia.com/phones/6600
Reading it may provide you with many more useful insights as to how to best use your phone for various things.
Similar problem:
I installed an application called MP3 Gravity, which I now want to uninstall.
The problem is that it does not appear in the Application Manager.
Actually, nothing appears in the Application Manager (no data),
while in the log file I can see all the applications that I have installed.
Any suggestions how to uninstall MP3 Gravity?
-magkas
download something called file explorer (FExplorer) or you can use an mmc reader
go into the folder E://system/apps and look for the mp3gravity folder
then delete the whole folder.This will remove the item from the menu as well
But it might not remove the mp3 recognition files as they are usually stored elsewhere in the phone.
How long did you wait in the App. Manager program? Sometimes it will take a while before it finds all your apps, depending on where it has to search, large mmc's can take a while. Or turn the phone off and then on again, look in the App Manager again to see if it was a tempory glitch.
