Drives in Nokia 7650 Phone
5 replies · 1,942 views · Started 04 October 2002
Anyone knows beside the 3 folders, what are the files at the root for? I think it's the appl i install b4, HandyExpense, HandySafe and HandyShopper.
C:/ Nokia folder
system foler
Video folder
Expense.dat 3KB
Expense.ind 1KB
Expense.tmp 0KB
Safe.dat 2KB
Safe.ind 648 KB
Safe.tmp 0 KB
Shopper.dat 15 KB
Shopper.ind 6KB
Shopper.tmp 0KB
Can i delete the dat, ind and tmp files at the root? Can anyone comfirm after deleting, will phone crash?
Please help :-?
Reason for deleting the files becoz the above mentioned appl have been expired. I can no longer uses em'.
I don't know if i wasted all those files, if i download a new copy and install into my phone, will my phone able to run of will not becoz i have exceeded the trial usage days? Or.. will it work after delete the dat, ind and tmp files from the C drive's root?
[quote="MaleBuffy"]The phone will not crash! But the apps might not work!
[/quote]
Well if they have expired you can delete them! I dont know if they work again! I would delete them and see if they still worked. If not I would unistall them anyways!
It's work when you deleted the old dat,ind and tmp files. The appl reseted it expiry dates again 😃
