STRANGE: saved words in T9 dictionary lost
2 replies · 2,885 views · Started 23 September 2004
strange one this. i have not done a factory reset or formatting of any kind on my 7610, but all the words i previously saved in my T9 dictionary have been lost
has anyone else had this problem?
I dont know if its a version problem but just in case, my version is:
4.0421.4
22-05-04
RH-51
(whats the most up to date version by the way)
Yes I have, but i dont think it deletes all of the word you entered. I think it works like this..... basically T9 seems to have an allocation of new words you can enter but once that allocation is full it starts substituting your old words for the new ones you are saving. does that make sense?
I have seen this bug reported on howardchui. It was posted that a new firmware is needed but there is none yet 😉. So its a bug.
