Symbian SIM 2 Toolkit API
1 replies · 2,112 views · Started 23 September 2004
Hi all,
I need to access the Symbian SIM 2 Toolkit API. I am aware that this API is not public and can be accessed with the right code. Would you know how to write a Symbian C++ program to access this API?
Thx in advance.
This is not possible due to the restriction imposed by OS. You may try other ways to comlete your task cheers
