AMR coding de-coding help
2 replies · 2,317 views · Started 04 October 2002
i am trying to code wav or midi files to amr but how??
the reason being i want to attach sound files for mms transfer but i the phone also accepts amr but not midi.
how would you send midi files to another phone?
i just followed the nokia link to the company which produces the amr codec and apparently they sell the coder & decoder software. i will give it a try, shame i have to pay...and freeware available??
http://www.voiceage-spot.com/html/spotxde_pro.asp
3G-compatible content is just a few clicks away with � Pro. Select the audio/video input files and convert them into a file format that can be read by the intended receiver.
�Pro's user-friendly interface eases the task of encoding, for personal and professional users alike. See it for yourself!
Use Settings to set encoding parameters such as output bit-rates and file size limits. Use Info to display or print input and output file information such as file formats and codecs, playing time and compression ratio. As an advanced user, bring into play Profiles to greatly simplify the process of setting up encoding session parameters, and switch easily from one session to another.
Design media rich communications for wireless handsets with � Pro! Download it now for $49.00 USD.
Well if you download the codec you can use several apps that use codecs to encode. Try searching in www.tucows.com and google. You might find encoders! Good luck!
