Can I Download ZIP Files Onto My NGAGE?
3 replies · 2,227 views · Started 23 September 2004
and unzip them? or do i have to put them on pc first then mmc?
hauntedsouls wrote:and unzip them? or do i have to put them on pc first then mmc?
If you have the ZIPMAN program in your phone you would be able to unzip them.
But if the are actuall Java apps and for some reason named with the .zip extension, just change to .jar and install as-is.
