Some lock program??
3 replies · 1,491 views · Started 23 September 2004
i was wondering if there is some symbian application that locksthe phone, so the acces to the messages, and contacts will be enabled only with the password, and other applications to work without pasword,... so if some one touches my phone to cant read messages,
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
U can lock all ur apps, just by using the lock code. Pres the switch off button, and you'll see lock phone. Press ok, and it'll ask for your lock code. After entering it, u will see that unless u re enter the lock code, u cannot access any app(except calls).
rohitkhannak wrote:Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
I think what he wants is a program that would limit the access of messages with all else accesible.
yes, Kamalayan i was looking for app. that lock ONLY messages and maybe contacts.. but all other apps could run. btw, thanks rohitkhannak i didn't know that for phone locking>..
