MMC size and music playback on N-gage
3 replies · 3,090 views · Started 23 September 2004
Is it possible to play music from a card larger than a 128mb mmc.... in the manual it says that music files can only be played from a 32 64 or 128mb mmc card... are these the only sizes that allow you to play music?
Stretch� wrote:in the manual it says that music files can only be played from a 32 64 or 128mb mmc card... are these the only sizes that allow you to play music?
Nope. Up to 1GB cards can be used, but not all brands are compatible (check the MMC compatibility thread).
Raven wrote:Nope. Up to 1GB cards can be used, but not all brands are compatible (check the MMC compatibility thread).
Thanks alot....
does anybody got mmc - apacer 256 or 512? i want to know if this brand works in ngage and qd
