Hi... :icon2:
I have a 3650 nokia phone. I have a very bad problem with it. when i turn it on it starts to show many error message [Application error.]. :frown:
all of the application on it don't work, even its built in application like contact manager and messag manager don't work.
itried to rert it to its default setting but problem don't go away. I tried hard rest code *#7370# but it doesn't work. when i enter code, phone ask lock code and when i enter the lock code [the lock code is correct. I tried some wrong lock code and phone shows error message 😃 ], nothing happend!
the most important problem is: PHONE IRDA PORT IS NOT WORKING!!!!
WHAT SHOUL I DO, PLEASE HELP ME IF YOU CAN!!! 😎 :con?
ashrah wrote:Hi... :icon2: I have a 3650 nokia phone. I have a very bad problem with it. when i turn it on it starts to show many error message [Application error.]. :frown:
Bad news ashrah... I think this is a really serious problem, and you need to get it reflashed from your nearest Nokia authorized dealer.
yes I think my phone must be flashed again!
thank you
Just did mine - had same problem. Take the MMC out before you do the reset - this is liekly to be where the corruption is.
If that works then switch the thing off and do a soft reset (hold down the [1ABC] key while switching back on
This should then allow you to reformat the MMC
I still hav problems..
Can somebody plzz help me.. M sure dere must b sum professionals here..
i cnt send things ova ma bluetooth n dnt get d image uploader menu in images
just found an ace piece of software and it WORKS my phone was hard locked and neede reformating but thisdid it no problem not sure if allowed to link but here goes all the w's nfader.z-host.ru/ if not just message me your iemi and i do it for u no probs works on 66 range as well i think
