I get this error "phone start up failed contact the retailer" Help man guys don't keep quiet atleast show me where to go!!!!!!!!!!!!!!!!!!
fLASHING NOKIA 7610
stevenokia7610 wrote:I get this error "phone start up failed contact the retailer" Help man guys don't keep quiet atleast show me where to go!!!!!!!!!!!!!!!!!!
Well Try Formatting i.e off your phone press Green answer key and *button and 3number key together and then on your phone then u see formatting on screen.
if still it shows the same then contact the retailer
but i think it will alright when u format it.
Vicky wrote:Well Try Formatting i.e off your phone press Green answer key and *button and 3number key together and then on your phone then u see formatting on screen.if still it shows the same then contact the retailer
what will be ereased when you formate the phone?
Misheck wrote:what will be ereased when you formate the phone?
When u format your Phone Whole your phone's "C" Phone Memory is Erased and it does not effect Sim and Memory Card Memory.
Vicky wrote:When u format your Phone Whole your phone's "C" Phone Memory is Erased and it does not effect Sim and Memory Card Memory.
what is installed on platform c?
By the way: how can I change the size of my RAM Drive on my Mobile Phone/ wich program do I need for oding this?
I hope you can understand me, my English is not the best..
Yikes, you are a real noobie huh? 😉 Let me see if I can help, what happens when you format a hard drive on your computer? Does the data on the other drives and the bios stay the same or get erased? Its the same with your phone. Format the phone and only the phone's memory is erased, the data on your MMC stays intact.
silkshadow wrote:Yikes, you are a real noobie huh? 😉 Let me see if I can help, what happens when you format a hard drive on your computer? Does the data on the other drives and the bios stay the same or get erased? Its the same with your phone. Format the phone and only the phone's memory is erased, the data on your MMC stays intact.
i know...i'm talking about the programs wich are installed on my phone...what kind of software is on the c drive...i oalso noticed that there is a z drive on my phone...what kind of stuff is on this drive?
sorry for getting you on your nerves
First of all, I should be apologizing to you for misunderstaing you and I am very sorry about that! Second, you are not getting on anyone's nerves 😃. Definately not mine 😊
As to your questions, hopefully I am getting it right this time 😉. what programs on on your 'C' drive depends on what you have installed. Sorry to be inprecise, but you can see the list if you use FE explorer and take a look at the system/apps directory on your 'c' drive. The Z dirve is the flash rom of the phone and cannot be edited with the proper hardware. Don't ask me what the 'd' drive is beacuse I have no idea. Can someone chime in? I think its the heap memory but I am not sure.
silkshadow wrote:First of all, I should be apologizing to you for misunderstaing you and I am very sorry about that! Second, you are not getting on anyone's nerves 😃. Definately not mine 😊As to your questions, hopefully I am getting it right this time 😉. what programs on on your 'C' drive depends on what you have installed. Sorry to be inprecise, but you can see the list if you use FE explorer and take a look at the system/apps directory on your 'c' drive. The Z dirve is the flash rom of the phone and cannot be edited with the proper hardware. Don't ask me what the 'd' drive is beacuse I have no idea. Can someone chime in? I think its the heap memory but I am not sure.
thanks
