hi,
how can i unlock 256 MB Microsim's MMC if i had formated nokia 6600 after forgetting password. Reply me soon on [email][email protected][/email]
unlock mmc
If you have formatted the phone, then there's nothing that can be done. Before formatting you would have been able to see the password in the "mmcstore" file on the C-drive, but since you reformatted the phone I'm afraid it is gone for good.
If you have really valuable information on the card, you could try a data recovery service like IBAS (http://www.ibas.com/data-recovery) but I'm not sure whether they can handle locked MMC cards (and the data has to be valuable, because the service will cost many times more than a new card, I'm sure).
pankajis2001 wrote:hi,
dear friend, try this, worked for me..!! one question first: you did a backup of your mmc with nokia your pc suite?? then...you are lucky..!! look in your pc the folder where those data were saved, normally : c:/nokia/nokia 6600/backup/filestore.dat.txt (mmmmm, maybe i would have to charge for this....!!!) open it, double click or with note pad, then......!!!!! hehehehe...there its is..!! the s...of...b.... code..!!! in my case its appear like this._: 000000�� VQ 7 7 8 8 , i used the last 4 numbers : 7788, and thats it...!!! you welcome...😊)) 😉
