6600 DUN on Bluetooth
3 replies · 2,006 views · Started 24 September 2004
Hi this is my first post on this forum I have used the search facility but despite finding a wealth of good info i cant find out how to use DUN on bluetooth, I am using a belkin bluetooth dongle and it works fine with pc suite but when i attempt to use DUN it wont allow it I am attempt to use my laptop (OS win XP) to connect to the internet through bluetooth.
Any help would be gratefull
thanks a lot
Peter
scorpio28 wrote:Hi this is my first post on this forum I have used the search facility but despite finding a wealth of good info i cant find out how to use DUN on bluetooth, I am using a belkin bluetooth dongle and it works fine with pc suite but when i attempt to use DUN it wont allow it I am attempt to use my laptop (OS win XP) to connect to the internet through bluetooth.
thanks a lot
Peter
Hi Anyone got any ideas to help me please.
Peter
Wot is DUN?
Are you trying to use the phone as a modem for the laptop?? If so perhaps more details on your network, your setting etc may help.
Are you using a dial-up or GPRS?
Install the phone as a modem via control panel > Use same com port as the belkin software for DUN (dial-up networking) > create a dial-up using either you isp's or your mobile networks GPRS settings and specify the 6600 bluetooth modem (also will need to specify APN (access poine name) in the pc/phone if using GPRS) > Connect!
Link here
