I have the Nokia 6600.I have 2 questions:
1:Is it possible to use a cable for connection it to a printer.
2: I have recently found out that there is a software camcorder that enables you to capture video for unlimited period. but it does not have the fast forward or the rewind options.Does anyone know if there is a software that has all the specifications of normal camcorder.
Thanks alot.
NOKIA 6600 queries
1: No. But you could print to a Bluetooth printer with an add-on printing application downloadable from http://www.nokia.com/nokia/0,8764,42291,00.html (it might also work through a PC, if the PC's Bluetooth software can support the Bluetooth Printing Profile with a printer connected to a PC locally or through the network).
2: Don't know. Try these two:
http://my-symbian.com/7650/applications/applications.php?fldAuto=970&faq=2
http://my-symbian.com/7650/applications/applications.php?fldAuto=467&faq=2
